I am trying to use query table to create a list of strings, mukey, associated with specific counties, to use for further geoprocessing with other tables in the same geodatabase. I created a dictionary with the county as the key and mukey as the value to query the list of mukeys. However, I have an error: CS1061 at "MUResults[county].Add(mukey)" saying there is no accessible extension method to Add. I am wondering what I can do to resolve this problem? Here is my script below:
using (Geodatabase geodatabase = new Geodatabase(connection))
QueryDef queryDef = new QueryDef
Tables = "MUPOLYGON.Name",
SubFields = "MUPOLYGON.OBJECTID, MUPOLYGON.AREASYMBOL, MUPOLYGON.MUSYM, MUPOLYGON.MUKEY",
QueryTableDescription queryTableDescription = new QueryTableDescription(queryDef)
Name = "MUTable",
PrimaryKeys = geodatabase.GetSQLSyntax().QualifyColumnName("OBJECTID", "AREASYMBOL"),
Table queryTable = geodatabase.OpenQueryTable(queryTableDescription);
using (RowCursor rowCursor = queryTable.Search())
while (rowCursor.MoveNext())
using (var row = rowCursor.Current)
var county = Convert.ToString(row["AREASYMBOL"]);
var mukey = Convert.ToString(row["MUKEY"]);
if (MUResults.ContainsKey(county))
MUResults[county].Add(mukey);
Thanks for your help!
There is no declaration of MUResults. But as I understand from your code, your last code line must be like that:
MUResults[county]= mukey;
// or
MUResults.Add(county, mukey);
As @GKmieliauskas mentioned you forgot to include the declaration for MUResults. With the correct declaration your code can work:
var MUResults = new Dictionary<string, List<string>>();
MUResults.Add("County1", new List<string>() { "First Item for County 1" });
if (MUResults.ContainsKey("County1")) {
MUResults["County1"].Add("Second Item for County 1");
Thanks Wolf! I did add the dictionary declaration, but I didn't declare the value, mukey as a List.
I changed my dictionary declaration from "var MUResults = new Dictionary<string, <string>>();" to "var MUResults = new Dictionary<string, List<string>>();"
Once I changed the mukey declaration, I have the following error "cannot convert from string to System.Collection.Generic.List<string>." How can I resolve this error? Thanks for your help!
Seem like the mukey is a string and not a list as declared in the dictionary.
@t499_gis wrote:Thanks Wolf! I did add the dictionary declaration, but I didn't declare the value, mukey as a List.
you have to know if the content in mukey column is a string or you want to have a list of item (so a list of string). I think just change the dictionary to new Dictionary<string, string> should be fine.
I used the community sample data for my code below, specifically the data in C:\Data\Admin\AdminData.gdb. Needless to say, i had to change the table names and field names. Here is the code for my sample button 'OnClick':
protected override async void OnClick()
try
var gdbFolder = @"C:\Data\Admin\AdminData.gdb";
var gdbPath = new FileGeodatabaseConnectionPath(new Uri(gdbFolder));
await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(gdbPath))
Tables = "PopulationByCounty",
SubFields = "OBJECTID, NAME, POP"
Name = "PopulationByCounty",
PrimaryKeys = geodatabase.GetSQLSyntax().QualifyColumnName("PopulationByCounty", "NAME")
var county = row["NAME"].ToString();
var mukey = row["POP"].ToString();
else
MUResults.Add(county, new List<string>() { mukey });
foreach (var county in MUResults.Keys)
System.Diagnostics.Trace.WriteLine($@"County: {county}");
foreach (var mukey in MUResults[county])
System.Diagnostics.Trace.WriteLine($@" MUKEY - {mukey}");
catch (Exception ex)
MessageBox.Show(ex.Message);
}And here some of the content (as output by my sample) for the dictionary:
County: Autauga County, Alabama
MUKEY - 54597
MUKEY - 54773
MUKEY - 54893
MUKEY - 55869
County: Baldwin County, Alabama
MUKEY - 182265
MUKEY - 183112
MUKEY - 199183
MUKEY - 223234
County: Barbour County, Alabama
MUKEY - 27455
MUKEY - 27327
MUKEY - 26755
MUKEY - 24686
County: Bibb County, Alabama
MUKEY - 22915
MUKEY - 22870
MUKEY - 22553
MUKEY - 22394
