QueryDef and Join
741
02-16-2022 06:16 AM
AnupamKumar
Are the RowCursor which are accessible by creating QueryDef and Join in ArcGIS Pro SDK  are read only?  Updating the Row iterating through RowCursor is not possible.
using (Table joinedTable = join.GetJoinedTable())
using(RowCursor rowCursor = joinedTable.Search(null,false))
while (rowCursor.MoveNext())
using (Row row = rowCursor.Current)
GKmieliauskas
Maybe it helps you:
https://community.esri.com/t5/geoprocessing-questions/edit-a-joined-table-arcgis-pro/td-p/546829
P.s.
"You can edit joined tables, but only the base table fields. Fields from the joined table are read-only."
https://pro.arcgis.com/en/pro-app/latest/help/data/tables/edit-an-active-table.htm
