Query Table Error
1105
09-29-2022 12:05 PM
tzz_12
I am wondering how I can fix this WhereClause? Everything seems to work, except for the query. Thanks for your help!
QueuedTask.Run(() =>
     string mKey = "462409";
      var ckeys = new string[3] { "19605542","19605543","19605707" };
       using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new  Uri(inPath))))
       using (var HzTable = geodatabase.OpenDataset<Table>("TableName"))
              foreach (var Ckey in ckeyList)
                  QueryFilter qf = new QueryFilter()
                         WhereClause = $@"ckey = {Ckey}",
                  using (var rowCursor = HzTable.Search(qf))  //error here
                     while (rowCursor.MoveNext())
                           using (Row row = rowCursor.Current)
                               Calculations performed here...etc.
KenBuja
MVP Esteemed Contributor
If you're filtering on a string field, you need to enclose the variable in quotes
WhereClause = $@"ckey = '{Ckey}'",
Wolf
by Esri Regular Contributor
Depending on the datatype of ckey field you might have to change your syntax so that:
could turn into this:
 Needless to say the field 'ckey' must exists in the table "TableName"
