ProStartPageConfig crashes when loading add-ins side-by-side
83
Monday
mahj
When running ProStartPageConfig in the ArcGIS Pro Add-In Samples (https://github.com/Esri/arcgis-pro-sdk-community-samples/) in ArcGIS Pro 3.6 with the Add-In Manager option "Load add-ins side by side" checked it crashes with the following unhandled exception:
System.Windows.Markup.XamlParseException: ''Add value to collection of type 'Microsoft.Xaml.Behaviors.BehaviorCollection' threw an exception.' Line number '212' and line position '14'.'
Inner Exception
Any idea how this can be fixed?
Markus
SelimDissem
A quick workaround is to comment out the source of the problem: lines 211->213 in ProStartPageSample.xaml in the UI folder of the solution.
Still looking into a fix, but this will get you running (Pro doesn't crash anymore)
mahj
Thanks for a quick response and workaround. But I guess the workaround affects some functionality? But it worries me that the underlying problem might affect other functionality in add-ins, so looking forward to a fix and a better understanding of the issue.
