Problems Adding Raster to GeoPackage
1338
06-02-2023 10:30 AM
RussellSuter
I'm trying to create a GeoPackage that contains a raster image using .NET and C#.  I was able to do something similar in Python but can't seem to get it to work in C#.  Here's the simplified code:
      private Task BuildExport ()
         string output = @"C:\Data\GeoPackage.gpkg";
         return QueuedTask.Run(() =>
            if (SelectedMapFeatures == null) return;
            try
               var parameters = Geoprocessing.MakeValueArray(output, "GEOPACKAGE");
               var result = Geoprocessing.ExecuteToolAsync("management.CreateSQLiteDatabase", parameters, null, null, null, GPExecuteToolFlags.None);
               foreach (var map in SelectedMapFeatures)
                  foreach (var feature in map.Value)
                     parameters = Geoprocessing.MakeValueArray(feature.Raster, output, feature.Name, "Tiled", null);
                     result = Geoprocessing.ExecuteToolAsync("conversion.AddRasterToGeoPackage", parameters, null, null, null, GPExecuteToolFlags.None);
            catch (Exception ex)
               Debug.WriteLine(ex.ToString(), Assembly.GetExecutingAssembly().FullName);
The GeoPackage is created just fine but adding the raster fails.  An exception is thrown on line 18 of the MakeValueArray for the first parameter:
TAKInterface, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null: System.InvalidOperationException: convert unsupported type
at ArcGIS.Desktop.GeoProcessing.ObjectToValueConverter.to_string(CoreObjectsBase b, Object& oref)
at ArcGIS.Desktop.GeoProcessing.ObjectToValueConverter.ToString(Object o, Object& oref)
at ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing.MakeValueArray(Object[] args)
at TAKInterface.TAKExporterDockPaneViewModel.<>c__DisplayClass26_0.<BuildExport>b__0() in C:\Users\...
The type for feature.Raster is RasterValue.  I've tried using feature.Raster.GetRasterDataset() with the same error.
So, the question I have, is how do I get my raster into my GeoPackage?
GKmieliauskas
The first parameter of "conversion.AddRasterToGeoPackage" is RasterLayer. See documentation:
Add Raster to GeoPackage (Conversion)—ArcGIS Pro | Documentation
So you need to add raster to map and then pass result RasterLayer to geoprocessing.
