Possible to pass Stream instead of file to Geoprocessing tools?
814
12-13-2022 06:12 AM
DanielRatzlaff
My add-in downloads zipped GeoJSON files and imports them with JSON to Features.  It would be handy to be able to pass a Stream (System.IO.Compression.ZipArchiveEntry.Open()) to the archived file instead of extracting the file to disk before importing.  Is this possible at all?
Wolf
by Esri Regular Contributor
The tool documentation only shows 'File' as valid input.  JSON To Features (Conversion)—ArcGIS Pro | Documentation
This enhancement has to be implemented by the GP Tool (or GP Tools since i can imagine that this feature would be useful across many tools), so i would suggest to either add this to ArcGIS Pro Ideas - Esri Community or upvote the item if it's already there.
For the time being you still have to stream into a temporary .json file and pass that to the tool.
Wolf
DanielRatzlaff
Thanks, Wolf.  I thought as much.  I did submit an Idea on the board.  If I'm understanding how the GP tools work, they seem to be fairly tightly coupled to Python, so to implement this feature might be tricky (translating the Stream to a structure Python understands) but if implemented it might work across all GP tools.  We'll see how it goes.  In the meantime, I'll just do what I can do.
