Persisting Add-In Data Into Pro Project
2068
12-10-2019 11:24 AM
MartinTyberg
In ArcObjects, it is possible to save add-in data directly into an MXD and to retrieve that when the MXD is loaded again. Is it possible in the ArcGIS Pro SDK to persist add-in data into an ArcGIS Pro project and later retrieve it when the project is loaded again?
Martin
Tags (1)
UmaHarano
With Pro, you can add content and images to an add-in and access them.
Here is a wiki page that discusses this: ProGuide: Content and Image Resources
MartinTyberg
Hi Uma,
Thanks. However, I need to save dynamic content that is generated when a user interacts with a dialog that my add-in raises. I'm thinking the best way to persist data is to retrieve the project's file geodatabase, create a new table in it, and store the data there.
Martin
Wolf
by Esri Regular Contributor
Hi Martin,
 Or you can implement 'custom project settings' as shown here: https://github.com/esri/arcgis-pro-sdk/wiki/ProGuide-Custom-settings
- Wolf
MartinTyberg
Hi Wolf,
That's exactly what I was looking for. Thanks alot for pointing me to it.
Martin
