Pane attributes defaultTab and defautlTool
2743
07-28-2021 05:07 AM
Eloy
Hi,  I have created a Pane for displaying data in a Table  just as follows.
<pane id="MarktAnalystPro_Modules_Planning_StatisticZonesTable" caption="Zonenstatistiken" className="MarktAnalystPro.Modules.Planning.StatisticZonesTableViewModel" smallImage="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/GenericButtonGreen16.png" defaultTab="esri_mapping_homeTab" defaultTool="esri_mapping_navigateTool" >
<content className="MarktAnalystPro.Modules.Planning.StatisticZonesTableView" />
</pane>
The pane I have created  behaves like a map and everytime the user makes this pane active,   the dockpane "Contents" is changed not showing the layers of the acutal active map. Is there a way to change the behaviour of the pane, like that of an attribute table for instance?. My guess is that we are supossed to change either the defaultTab or the defaultTool attributes, but I haven't found any information regarding other options besides "esri_mapping_homeTab" or "esri_mapping_navigateTool".
Thanks in advance, Eloy
NarelleChedzey
Eloy,
Please review this documentation regarding Pane impersonation.  In order for the TOC / contents pane to still show active map content, your pane needs to "impersonate" the mapView.
https://github.com/Esri/arcgis-pro-sdk/wiki/ProGuide-Map-Pane-Impersonation
And an associated sample
https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Map-Exploration/ImpersonateMapP...
Hope this helps
Narelle
GKmieliauskas
If you want to see layers of actual map when your pane is selected you need to set <content className=<esri contents dockpane class name>.
I have found in ADCore.daml reference to ArcGIS Pro Contents dockpane:
<dockPane id="esri_core_contentsDockPane" caption="Contents" className="ContentsDockPaneViewModel" dock="left" width="320" keytip="toc" delayLoadMessage="Open a map or layout view">
  <content className="ContentsDockPane" />
  </dockPane>
So you could try to change your content className, to ArcGIS Pro "ContentsDockPane". I don't if ArcGIS Pro will know that  is ArcGIS Pro class. Maybe you need to specify some path to that className. Esri stuff could say more about that.
Eloy
Thanks for answering.  What I really want is to display my own pane without causing changes in the dockpane "ContentsDockPane". If I change the content from my own class to "ContentsDockPane" then my pane will be no displayed (Screenshot below). I guess there is something I don't understand about panes in ArcGIS Pro.
Thanks again
GKmieliauskas
From your question I understood that you want to have Esri layer content pane.
Check your layers control binding and try to update binding property in overridden OnActivate method.
It is hard to help without the code.
NarelleChedzey
Eloy,
Hope this helps
Narelle
Eloy
Thanks, that is great. In the "create" method of the pane, you are allowed to bind the desired map with the pane.
Thanks again!
