Open/Save/Coordsys Dialog Error
1345
03-03-2020 07:24 AM
AdamDavis
At 2.5 still having issues getting dialogs to show correctly when used from within QueuedTask.Run.
The Coordinate System Dialog is the one from the snippet collection
This works from a button
protected override void OnClick()
new SaveItemDialog().ShowDialog();
new CoordinateSystemDialog().ShowDialog();
So does this
FrameworkApplication.Current.Dispatcher.Invoke(() => new SaveItemDialog().ShowDialog());
FrameworkApplication.Current.Dispatcher.Invoke(() => { new CoordinateSystemDialog().ShowDialog(); });
But this does not.
QueuedTask.Run(
The coordinate system dialog never completes loading. The Open/Save Dialogs do not show the contents of a fgdb. If I run the command again in the same session then the Open/Save Dialogs show the contents of a fgdb
Is there a workaround whilst it's being fixed?
Adam
CharlesMacleod
In general, calling a modal dialog from the queued task should be avoided.
    //construct on the UI
    var dlg = new SaveItemDialog();
    dlg.Title = "On QueuedTask";
    QueuedTask.Run(() =>
	  var result = dlg.ShowDialog();
AdamDavis
Hi Charles,
Thanks for the code. I tried that and no difference - the first time the button is used entering a filegdb gives an infinitely scrolling wait icon. The 2nd time the button is used it shows the contents immediately.
it would be great if this could be made to work within the API whilst in QueuedTask.Run(). The realities of a very large code base don't always allow for being able to nip on/off the MCT at will. We have a code base that is entirely synchronous and are so are pragmatically wrapping our entire command in a single QueuedTask.Run().
Adam
