Open a non-earth map?
1426
07-10-2017 10:28 PM
jackpearson
I am importing a point featureclass, layer which are non-earth (e.g. local project coordinates)
How would i create a map with non-earth coord system ?
currently i'm using :
Map map = null;
await QueuedTask.Run(() =>
map = MapFactory.Instance.CreateMap(mapName, MapType.Map, MapViewingMode.Map, Basemap.None);
await ProApp.Panes.CreateMapPaneAsync(map);
MelitaKennedy
Esri Notable Contributor
Hi Jack,
I won't be much help on the developer-side, but I wanted to ask about the coordinate system you're using. You mention local project coordinates as well as "non-earth". I'm used to seeing "non-earth" used in connection to MapInfo or Oracle (?). Am I correct?
As a long-shot, the data could also be extraterrestrial like on Mars or the Moon. That's not true, is it?
Are there any ties to the earth? Sometimes it's possible to define a custom projected coordinate system for a local system if there is some information tying it to the earth OR control points exist in that system and a 'known' system like a UTM zone.
And for someone who understands the programming side better, are you getting errors with the code you posted?
Thank you,
Melita
jackpearson
Thanks Melita,
Long shot - Star pickets on mars ?
No, sometimes we need to work with customer data which is on an arbitrary
local project coordinate system and has not been tied in to an earth
spatial ref.
So we would be looking to open a map that accepts arbitrary rectangular 2d
coords.
Obviously we would expect to be able to project data on other coordinate
systems into this map.
Regards,
Jack Pearson
Fremantle Technology / Go-Global Internet Solutions
jackpearson
And no my code works fine, but by default the map seems to be set to WGS84
Regards,
Jack Pearson
MelitaKennedy
If you're interested, drop me an email (mkennedy at esri dot com) and I can send you a document that discusses working with local coordinate systems.
Melita
