Open a feature class
2090
09-08-2022 06:55 PM
JeromeHaaland
The GetBoundary() method below returns the string path to a feature class.
How is the string path to the feature class used instead of the code on lines 25 and 26?
protected override async void OnClick()
            string extent = await Extent();
            MessageBox.Show(extent);
            static async Task<string> Extent()
                string results = "";
                static string GetBoundary()
                    OpenItemDialog item = new OpenItemDialog();
                    item.Title = "Select the Boundary";
                    item.MultiSelect = false;
                    item.ShowDialog();
                    return item.Items.First().Path;
                await QueuedTask.Run(() =>
                    // Want to use this path name to create a feature class
                    string boundary = GetBoundary();
                    // This is fine... except how are the 2 lines below made to run from an OpenItemDialog
                    Geodatabase gdb = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("C:\\Temp\\Learn.gdb")));
                    using (FeatureClass fc = gdb.OpenDataset<FeatureClass>("CSS_1_BoundaryBuffer"))
                        string xMax = fc.GetExtent().XMax.ToString();
                        string xMin = fc.GetExtent().XMin.ToString();
                        string yMax = fc.GetExtent().YMax.ToString();
                        string yMin = fc.GetExtent().YMin.ToString();
                        results = $"{xMin} {yMin} {xMax} {yMax}";
                return results;
JeromeHaaland
Excellent Reply... Worked well.
FYI for others, the Path.GetDirectoryName() needs the "using System.IO;" statement
GKmieliauskas
Your code structure isn't correct. You need to separate UI and work tasks first. I would do it like that:
            item.ShowDialog();
        static async Task<string> Extent(string fcPath)
                Geodatabase gdb = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(Path.GetDirectoryName(fcPath))));
                using (FeatureClass fc = gdb.OpenDataset<FeatureClass>(Path.GetFileName(fcPath)))
            return results;
            string fcPath = GetBoundary();
            string extent = await Extent(fcPath);
I have added fcPath parameter for your Extent method. fcPath parameter value separated by Path methods to Directory and File name.
I would recommend to use FeatureClass filter in your GetBoundary method.
https://github.com/Esri/arcgis-pro-sdk/wiki/ProSnippets-Browse-Dialog-Filters
JeromeHaaland
