Not able to undo after EditOperation.Execute()
1466
05-17-2023 12:22 AM
OscarYam
I created a custom function to update a feature attribute.
I started by adding a dock pane and binding an update action to a button.
The update was a success, but I cannot undo it with the built-in undo button of ArcGIS Pro, which is dimmed. I can only discard the edit by using the discard button. I am wondering what's wrong. I would be grateful if anyone could point me in a direction.
part of the dock pane xaml
<Button Content="Update"
Command="{Binding Update}"/>
part of the C# of the ViewModel
private ICommand update;
public ICommand Update
	get
		if (update == null)
			update = new RelayCommand(() => UpdateFeatureNumber());
		return update;
private void UpdateFeatureNumber()
	QueuedTask.Run(() =>
		EditOperation editOperation = new EditOperation
			Name = "Update Attribute"
		editOperation.Modify(currentRow, "Field", value);
		if (editOperation.Execute())
			ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Updated.", "Update Attribute", MessageBoxButton.OK, MessageBoxImage.Information);
			return;
by Anonymous User
Not applicable
You need to override OperationManager method of your dockpane:
        public override OperationManager OperationManager
            get
                return MapView.Active?.Map.OperationManager;
More info you can find here:
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic10432.html
https://github.com/Esri/arcgis-pro-sdk/wiki/ProGuide-Dockpanes
Wolf
by Esri Regular Contributor
In order to use Undo/Redo you have to 'save' your edits first.  More details are here:  ProConcepts Editing · Esri/arcgis-pro-sdk Wiki (github.com)
In short these are the relevant methods:
