New Button on Versions Tab
1836
11-19-2021 02:35 PM
pspada_WT
Hi, I'm trying to develop an Add-in that add a new button to the versions Tab.
It's possible?
Thanks for the help
Wolf
by Esri Regular Contributor
You can create a module add-in project, then add an ArcGIS Pro button in that project.  By default the button will be on an add-in tab.   Now you have to modify the content of the config.daml to insert your button into another tab, group, etc.   This document gives an overview of DAML:  ProConcepts Framework · Esri/arcgis-pro-sdk Wiki (github.com)
here is a video:
ArcGIS Pro SDK for .NET: Working With DAML - YouTube
Also this sample modifies an existing ArcGIS Pro tab:
arcgis-pro-sdk-community-samples/Framework/WorkingWithDAML at master · Esri/arcgis-pro-sdk-community...
Now you need to find the daml id for the version tab / group into which you need to add your button.
To find the daml id you can use the 'Show command IDs' option in ArcGIS Pro:
Or use the DAML ID reference:
ArcGIS Pro DAML ID Reference · Esri/arcgis-pro-sdk Wiki (github.com)
Wolf
here is a video:
pspada_WT
Hi thanks a lot for your help!!!
I've one last question. I've built a test with a button in the geoprocessing group in the analysis tab and it works.
But when i test with the Versioning group in the Versioning tab It don't.
I think the refID are right. What I'm doing wrong?
pspada_WT
I've figure out. I have put a wrong module name. I've used "esri_mapping_module" but is "esri_mapping".
