Nearest Feature
2330
6
08-16-2024 04:13 AM
sonj
In arcobjects we used to find the nearestfeature using IIndexQuery. Is there similar functionality in Pro SDK? If not what is the best process to find the "NearestFeature"
sonj
It is working by changing the parameters. It may be helpful to others hence sharing code snippet.
var parameters = Geoprocessing.MakeValueArray(pointFeatureClass, targetFeatureLayer, "NEAR_FID NEAR_FID;NEAR_DIST NEAR_DIST");
Aashis
by Esri Contributor
Have you looked into the GeometryEngine.Instance.NearestPoint?
sonj
IIndexQuery takes IFeatureIndex.FeatureClass is my target FeatureLayer so IIndexQuery.NearestFeature will return the feature ID of the target layer. Pro SDK NearestPoint function takes geometry—the objective is to find the nearest feature ID from a specific featurelayer. If I know the geometry my problem is resolved.
sonj
Is there anyone here that can assist me? I did some research on Analysis.Near(). The functionality is almost exactly what we need, except it updates the closest feature ID and adds new fields. We have no desire to update client data.
GKmieliauskas
You can create temporary GDB for Analysis.Near(). Clean and fill it with your analysis data each time.
sonj
The Analysis.Near code is executing but the Point layer is not updating.
await QueuedTask.Run(async () =>
	Table targetFeatureTable = targetFeatureLayer.GetTable();
	string pointFeaturePath = pointFeatureClass.GetPath().ToString();  // point feature layer
	string targetFeaturePath = targetFeatureTable.GetPath().ToString();  // polyline feature layer
	var environments = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
	var parameters = Geoprocessing.MakeValueArray(pointFeaturePath, targetFeaturePath, "NO_LOCATION", "NO_ANGLE", "PLANAR", "NEAR_FID NEAR_FID;NEAR_DIST NEAR_DIST");
	IGPResult result = await Geoprocessing.ExecuteToolAsync("analysis.Near", parameters, environments);
	// Check the result
	if (result.IsFailed)
		throw new Exception("Near tool execution failed: " + result.ErrorMessages);
sonj
