Navigating a map with mouse wheel while add-in tool is active reverts to Explore tool
1426
07-28-2022 12:54 PM
TimWhiteaker
In Pro 3.0.0, I created an add-in following Build a map identification tool tutorial.  In a map in Pro, when I click on the custom tool to activate it, it is active.  Then if I scroll or click and drag with the mouse wheel to navigate in the map, the active tool reverts to being the Explore tool.  In Pro 2.x, if I navigated with the mouse wheel, the currently active tool would remain active.  I prefer the 2.x behavior.  Can I make Pro 3.0 keep my current tool active after navigating with the mouse wheel?
Wolf
by Esri Regular Contributor
I was able to duplicate this issue.  It is a bug.  I also noticed that when you change this line in the constructor from this:
SketchOutputMode = SketchOutputMode.Screen;
to this:
SketchOutputMode = SketchOutputMode.Map;
This will limit your tool to Maps only it will not work on Scenes (3 D), however, the active tool doesn't switch to the Explore tool anymore.
TimWhiteaker
That is a nice workaround as long as one doesn't need the tool to work in Scenes. I noticed what is perhaps another bug related to the workaround. There are different click behaviors for these situations:
When SketchOutputMode = SketchOutputMode.Map, you click once to start the sketch, drag to draw the shape, and click again to end the sketch.
When SketchOutputMode = SketchOutputMode.Screen, you click once to start the sketch and keep the mouse button held down, drag to draw the shape, and then release the mouse button to end the sketch.
