Missing TABLE_ID_GENERATOR in SDE
1037
01-26-2023 07:00 AM
Meroni
Hi, I am trying to create a feature class and schemaBuilder.Build() yields the following error:
CreateAnnotationFeatureClass
test_t
Error: The table already exists.
However, there is no table test_t in the SDE. After researching a bit I stumbled upon the following link https://support.esri.com/en/technical-article/000006563 . The workaround should solve the problem (at least that is what I believe). The problem is that the SDE has no sequences and the workaround mentions that I have to call
SELECT last_number FROM user_sequences WHERE sequence_name = 'TABLE_ID_GENERATOR';
However, since there are no sequences I can't even complete the first step of the workaround.
Question is, why are there no sequences in my SDE?
Aashis
by Esri Contributor
Probably the DBMS is caching some information about the feature class.
I would begin troubleshooting by manually removing the entry of the feature class from the GDB_ITEMS table and then recreate it.
