MapTool that selects only one feature
2347
07-21-2022 12:58 AM
KhaledAliMoh
How to create a map tool that selects only one feature when click on a point with a tolerance.
For now I can use ActiveMapView.SelectFeatures(geometry), but this method can select multiple feature layer or multiple feature in a layer.
var selection = ActiveMapView.SelectFeatures(clickedPoint, method: SelectionCombinationMethod.New);
KhaledAliMoh
I don't know what you mean by
// this statment
oids = oid;
However I was able to get the answer from the method you have mentioned GetFeatures(geometry).
Thank you for your help.
CharlesMacleod
You most likely want FeatureLayer Select(...). https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic11392.html
Something like:
 var sqf = new SpatialQueryFilter() {
   FilterGeometry = clickedPoint,
   SpatialRelationship = SpatialRelationship.Intersects,//change as needed
   WhereClause = "Optional SQL whereclause here",
   SubFields = "*"
 var selection = featLayer.Select(sqf);
KhaledAliMoh
How can I get the featureLayer ?
DavidMrázek
What about this:
 var features = mapView.GetFeatures(point);
                if (features.ContainsKey(layer))
                    var tag = features.FirstOrDefault(t => t.Key == layer);
                    var oids = tag.Value;
                    foreach (var oid in oids)
                        oids = oid;
var filter = new QueryFilter
                WhereClause = " OBJECTID = " + oid
 var select = layer.Select(filter);
KhaledAliMoh
// this statment
oids = oid;
