How do I refresh an sde connection to see updates to a feature class?
4847
6
05-30-2019 02:19 PM
JeremyRogers1
I have created a button that fires a stand alone python script. The script will update a row in a feature class that exists in an sde. I have that same feature class in my map in the aprx. Once the script has fired I want to see the updated row in the attribute table. If I manually refresh the sde connection in my database connection folder inside the aprx it will not update the row. However, if I were to right-click on the sde database and select properties this will cause a "refresh" and the update will become visible in the attribute table. I am attempting to duplicate this "refresh" action in C# once the python script has finished but I'm striking out. Any suggestions would be appreciated.ArcGIS Pro SDK
RichRuh
Is this a versioned feature class?  And, if so, regular or branch versioning?
--Rich
JeremyRogers1
It is versioned using branch versioning.
RichRuh
The routine you are looking for is Version.Refresh
From the feature class, get the Geodatabase.  Geodatabase.GetVersionManager() will get you a VersionManager.  VersionManager.GetCurrentVersion() will get you a Version object.
--Rich
JeremyRogers1
Boom! Thank you!
Geodatabase gdb = layer.GetFeatureClass().GetDatastore() as Geodatabase;
VersionManager versionManager = gdb.GetVersionManager();
ArcGIS.Core.Data.Version version = versionManager.GetCurrentVersion();
version.Refresh();
Worked perfectly!
StevenDel_Favero
Is there a way to do this within arcpy? In order to see my edits to a layer from a versioned feature class I have to righ-click the sde connectin and hit Properties or restart ArcPro.
caseysmith_DCP
I've also been looking for a solution to this.
