Load a feature layer form a GeoPackage
2408
06-18-2024 08:17 AM
GloboGlobo
Hi all,
is it possible to load a Feature Layer from a GeoPackage without adding it to the map ?
I'm using ArcGIS Pro SKD version 3.2 with Visual Studio 2022.
Tags (1)
nicogis
In ArcGIS Pro 3.3 you can load  using similar code
string path = "c:\Temp\dbgt.gpkg";
var datastore = new Database(new SQLiteConnectionPath(path))
var database = _datastore as Database;
IReadOnlyList<string> tableNames = database.GetTableNames();
foreach (string tableName in tableNames)
				QueryDescription queryDescription = database.GetQueryDescription(tableName);
				TableDefinition tableDefinition = database.GetDefinition(queryDescription);
    if (queryDescription.IsSpatialQuery())
        FeatureClass b = (FeatureClass)database.OpenTable(queryDescription);
				else
        Table a = database.OpenTable(queryDescription);
nicogis
				else
MK13
@nicogis I get the error below when I attempt to open a table in snowflake. Do you know what would be a good solution for the error?
GloboGlobo
Thanks so much, that's what I was looking for
NarelleChedzey
Sometimes there is other data that is in the geopackage file (for example raster data) that is not returned by the Database.GetTableNames method.
In this instance you could use the the ItemFactory and Item classes to obtain the content.   Here's an example snippet.
var otherUris = new List<Uri>();
var tableUris = new List<Uri>();
var item = ItemFactory.Instance.Create(gpkgPath, ItemFactory.ItemType.PathItem);
var children = item.GetItems();
foreach (var child in children)
   var childPath = child.Path;
   if (child.TypeID == "sqlite_table")
     tableUris.Add(new Uri(childPath));
   else
     otherUris.Add(new Uri(childPath));
// now use LayerFactory and StandloneTableFactory to
//  create layers / tables
