Layer selectable status changed event
1298
09-17-2019 01:28 PM
AlexZlotin1
Is there an event that is raised when a feature layer "selectable" status changes in a Pro map? Or is there perhaps a more general event which fires when any layer property changes? I have a custom panel with a list box that allows to control selectable status for a predefined set of layers, and this list needs to be in sync with the default "List by Selection" in Pro TOC. Thanks.
UmaHarano
Hi Alex,
The MapMemberPropertiesChangedEvent gets fired when a layer's selectable status changes. If you store the layers current status, then you can compare against that when this event fires.
Uma
AlexZlotin1
Thanks Uma!
