Issue with MosaicRule.WhereClause?
1837
06-10-2019 02:54 PM
ChrisGreen
I'm attempting to set the WhereClause on a MosaicRule against the ESRI Landsat imagery service. I can lock the raster to a list of ObjectIds, but a something like Name='LC82220782017324LGN00' doesn't work. I use to do something similar in ArcObjects with no issue. Am I doing something wrong? Thanks for your time, cg.
Prashant_MukeshMangtani
Chris,
Did you try the same query using the layer properties to see if its valid?
-Prashant
ChrisGreen
Yes, that did work when I did it manually (i.e., setting definition query of layer added). Is there a way to programmatically do the same thing, as I couldn't figure that out. I'd assume the where clause of the mosaic rule, which worked in ArcObjects, would work in the Pro SDK.
Thanks for your help, cg.
ChrisGreen
A big thanks to Kimberly (ESRI support) and ESRI for figuring this out for me.  Here's how to work this using a definition expression which gets the job done for my needs.
Map _map = await FindOpenExistingMapAsync("Map");
string layerName = "Landsat\\MS";
string imgServicePath = "http://landsat.arcgis.com/arcgis/rest/services/Landsat/MS/ImageServer";
ImageServiceLayer isLyr = null;
await QueuedTask.Run(() =>
                isLyr = (ImageServiceLayer)LayerFactory.Instance.CreateRasterLayer(new Uri(imgServicePath),
                _map, LayerPosition.AutoArrange, layerName);
                CIMImageServiceLayer cimLyr = isLyr.GetDefinition() as CIMImageServiceLayer;
                CIMFeatureTable cimTable = cimLyr.FeatureTable;
                cimTable.DefinitionExpression = "Name IN ('LC80440302019155LGN00','LC80440312019155LGN00')";
                Layer layer = isLyr as Layer;
                layer.SetDefinition(cimLyr);
