Is there a way to determine if an event listener has already been created with a RowCreatedEvent (or Deleted, Changed)?
976
08-09-2019 08:05 AM
FrankMartin1
I've created an add in button that subscribes to a RowChangedEvent for each layer in a map.    If another layer is added to the map and the add in button is executed again,  each of the previous layers that already were subscribed will now have an additional event listener.  Is there a way to determine if an event listener (RowChangedEvent) is already associated with a layer so I can prevent a additional ones from being created?
Thanks for your help!
Frank
Tags (1)
KoryKramer
Esri Community Moderator
Is this an ArcGIS Pro SDK‌ question?
FrankMartin1
Sorry. Yes, it’s an ArcGIS Pro SDK question.
by Anonymous User
Not applicable
Hi Frank,
There's nothing currently in the public API you can use to determine if a layer has an associated event.
You could maintain a collection (list or dictionary) of layers that have been subscribed to and check the list when iterating through the map layers again. Use the Layer.URI property to ensure uniqueness.
FrankMartin1
Thanks, Sean.   I  thought that might be the case.  I'll give the collection a try.
Thanks again,
Frank
