Hi there,
I digged a bit deeper into the behaviour of map graphics and their CIM representation in a MapDocument and LayerDocument and found probably some bugs or atleast inconsistencies when working with them.
The map graphic binary reference is lost when parsing a .mapx file back to a CIMMapDocument instance.
// map needs to have a graphic layer with graphics ofc
map.SaveAsFile("C:\\temp\\temp.mapx", true);
var json = File.ReadAllText("C:\\temp\\temp.mapx");
var mapDoc = CIMMapDocument.FromJson(json);
// BUG :: BinaryReference.Object is null. Should be instance of CIMElementStorage
var binaryRefs = mapDoc.BinaryReferences.Where(br => br.Object is CIMElementStorage).ToList(); // returns noneSame behaviour can be observed when doing this with a .lyrx file.
var layerDoc = new LayerDocument(graphicLayer);
layerDoc.Save("C:\\temp\\temp.lyrx");
// The .lyrx file contains the CIMElementStorage object
var json = File.ReadAllText("C:\\temp\\temp.lyrx");
// BUG: BinaryReference.Object (CIMElementStorage) is null, although it does exist in the .lyrx file json
var cimLayerDoc2 = CIMLayerDocument.FromJson(json);This two are probably just some parsing errors but the last one just does not make any sense to me. If I get the CIMLayerDocument in memory the CIMElementStorage object exists, but somehow the coordinates of the different graphic geometries are manipulated/odd in comparison when I do a proper save to .lyrx file.
// BUG: The resulting geometries within the CIMElementStorage have completely different geometries, see image below
// geometries are broken
var cimLayerDoc = layerDoc.GetCIMLayerDocument();
// geometries are ok
Left the geometry saved as .lyrx and right the in memory create CIMLayoutDocument. The source is exactly the same.
Any explanations or hints on this would be appreciated!
Weird. I wonder if the coordinate system used between both formats is different?
The spatial reference is actually the exact same. Its the same source map and the same source geometry.
