In memory workspace
16009
20
07-27-2020 02:53 AM
ModyBuchbinder
Hello all
I could not find any class or example for in memory workspace.
From the other hand there are many arcpy examples with in memory.
So (for example) if I run a GP tool from the SDK and let arcpy create a feature class in memory how do I access it from my code after it was created.
SarahHartholt
I'm using ArcPro 2.9.0 and am trying to use the "memory\mydata" format to join 2 layers in ModelBuilder. The documentation clearly states that I should not add a file extension. However, when I enter "memory\JoinParcelstoTable" to the Output Dataset box and click away ".shp" is automatically added to the end of my in memory folder path. When I try to run my model it fails on this tool. Any insights would be appreciated.
