I'm looking for something similar as "IGraphicsContainer" in ArcObjects.
1386
10-13-2016 12:41 PM
CollinKleiboer
I want to display a (temp) geometry in ArcGIS Pro. In ArcMap there is the IGraphicsContainer, which I can use. I'm looking for something similar in Pro SDK, but can't find it. Is this upcoming or do I need to create a workaround?
Tags (1)
UmaHarano
Hi Collin
Here is a sample that contains three different examples of working with Pro's graphic overlay: https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Map-Exploration/OverlayExamples
There are also some code snippets available here: https://github.com/ArcGIS/arcgis-pro-sdk/wiki/ProSnippets-MapExploration#graphic-overlay
Uma Harano
ArcGIS Desktop SDK Team.
CollinKleiboer
Hi Uma,
Thanks for your help. It's simpler than I thought, I just have to use the MapView.
Your url's are pointing to an unknown source, so I'll repeat them here:
https://github.com/Esri/arcgis-pro-sdk/wiki/ProSnippets-MapExploration#graphic-overlay
Thanks!
Best regards,
Collin Kleiboer
GisSense BV
