How to wait for MapView to Load?
8208
7
10-24-2017 01:05 PM
MKa
In my configuration project, my startup page allows a user to pick a "Location", using this location I create a new project for them.  I then want to get the MapView and load up some feature layers for that location and zoom to that location.  But it seems i have to wait for the Map to load before i can do what I want.
So I call this Command from my xaml BlankProjectCommand
public ICommand BlankProjectCommand
      get
         return new RelayCommand((args) => BlankSelectionViewModelHelper.NewBlankProject(_Location), () => true); ;
Then it returns this function NewBlankProject, but the following function wont work fully because i cant reference the MapView.Active.Map as I want to load some feature layers for the Location and zoom to that location.  Is there anyway I can wait for the map to load after var newProject = await Project.CreateAsync(cps);
internal static async void NewBlankProject(string inLocation)
     string defaultName = inLocation;
     string defaultFolder = DefaultFolder();
     string templatePath = GetDefaultMapTemplate(); //Map
     if (!string.IsNullOrEmpty(defaultFolder) && !string.IsNullOrEmpty(templatePath))
          var cps = new CreateProjectSettings()
               Name = defaultName,
               LocationPath = DefaultFolder(),
               TemplatePath = GetDefaultMapTemplate()
          if (MapView.Active != null && MapView.Active.Map != null)
               MapSettings newMapSettings = new MapSettings();
               newMapSettings.PlantCode = inPlantCode;
               newMapSettings.HarvestYear = inHarvestYear;
               newMapSettings.HarvestTrimester = inHarvestTrimester;
               newMapSettings.MaterialGroup = inMaterialGroup;
               newMapSettings.Environment = Settings.CurrentEnvironment;
               List<UserPlantData> UserPlantDataList = new List<UserPlantData>();
               UserPlantDataList = await WebServiceUtility.GetUserPlantDataAsync();
               if (!newMapSettings.Equals(Settings.CurrentMapSettings))
                    await FeatureServiceManagement.LoadFeatureServiceAsync(newMapSettings);
                    await Navigation.ZoomToPlantExtentAsync();
Tags (1)
UmaHarano
Hi
When you open a project with a Map View, you can wait for the MapView to initialize by subscribing to the "MapViewInitialized" event (topic12855.html).  Important thing to note is that when you open a new view in your project, this event will be triggered again.
If you want to subscribe to the MapViewInitialized event as a one shot per project, you will have to:
  • Unsubscribe after the MapView has initialized the first time when the project opens.
  • Then subscribe to the ProjectOpenedEvent and then check if the MapView is again initialized. (for subsequent Project open routines)
Here is a code snippet to subscribe and unsubscribe to the MapViewInitialized event.
private SubscriptionToken _eventToken = null;
 protected override bool Initialize()  //Module initialized
            _eventToken = MapViewInitializedEvent.Subscribe(OnMapViewInitialized);
            return base.Initialize();
        private void OnMapViewInitialized(MapViewEventArgs args)
            MessageBox.Show("MapView has been initialized");
            if (_eventToken != null)
                ArcGIS.Desktop.Mapping.Events.MapViewInitializedEvent.Unsubscribe(_eventToken);
                _eventToken = null;
Thanks
Uma
BarbaraSchneider2
Hi Uma,
thanks for your input. Your code above works fine for me when I first show the message box ("MapView has been initialized") and then access the active map (MapView.Active.Map). When I remove the message box, however, the active mapview is null. How can I get around this?
Barbara
UmaHarano
Hi Barbara
The best way to ensure that the MapView initialization is complete and a MapView is available is to use the DrawCompleteEvent.
The arcgis-pro-sdk-community-samples repo has a few examples:
https://github.com/Esri/arcgis-pro-sdk-community-samples/search?q=DrawCompleteEvent&unscoped_q=DrawC...
Thanks
Uma
RishabhRaj29
Hi @UmaHarano , the link is broken. Can you please share the sample again? Thanks!
RadekMandovec
Hi Uma,
this works fine for MapView, but is there any way to do something similar for LayoutView? I tried different events, but none of them works for me.
Radek
GKmieliauskas
Try to subscribe to ArcGIS.Desktop.Layouts.Events.LayoutViewEvent and check args.Hint == LayoutViewEventHint.DrawingComplete. LayoutViewEventHint Enumeration here.
BarbaraSchneider2
Hi Uma,
this works, thank you!
