How to Set SDE-added Layers as Read-Only, Uneditable?
647
02-22-2024 07:03 PM
MaxW
I'm using the method new FeatureLayerCreationParams(new Uri(XXX)) to add layers from SDE to the map. How can I set the added layers as read-only and uneditable?
UmaHarano
Here is a code snippet that sets a FeatureLayer to be uneditable.
QueuedTask.Run(() =>
  var cimFeatureLayer = layer.GetDefinition() as CIMFeatureLayer;
  var featureTable = cimFeatureLayer.FeatureTable;
  featureTable.Editable = false;
  cimFeatureLayer.FeatureTable = featureTable;
  layer.SetDefinition(cimFeatureLayer);
UmaHarano
MaxW
Thank you so much.
