If you select a north arrow in a layout in ArcGIS Pro and go to Symbol>Properties>Halo, you can set the halo property of a north arrow.
Does anyone know how to access this property programmatically in the ArcGIS Pro SDK?
//I am assuming the selected item is a north arrow
var northArrow = LayoutView.Active.GetSelectedElements().First();
QueuedTask.Run(() =>
//CIMTopoNorthArrow is a different beast entirely...
var cim = northArrow.GetDefinition() as CIMMarkerNorthArrow;
//this halo symbol is 50% transparent, no outline (i.e. 0 width)
((CIMPointSymbol)cim.PointSymbol.Symbol).HaloSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.CreateRGBColor(0,0,0,50)),
SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB,0));
((CIMPointSymbol)cim.PointSymbol.Symbol).HaloSize = 3;//size of the halo
//set it back
northArrow.SetDefinition(cim);
//set it back
Works great, thank you! I was casting northArrow.GetDefinition() as CIMNorthArrow which was just the same as accessing the NorthArrow property of NorthArrowStyleItem.
Two things that may help:
1. When working with the CIM, I often set a line like this in my code: var str = cim.ToXML();
Then, in the debugger, I set a breakpoint on that line and now I can hover over "str" and use the text or xml viewer built in to visual studio to examine "str". [I am not sure if you realize but the CIM definition is serializable to XML]. Note that the "type" of each element is shown in the XML as well as the structure.
2. Use the CIM Viewer. It is a utility we (Pro SDK team) wrote for examining the CIM. You can find it here: arcgis-pro-sdk-cim-viewer
It allows you to see the CIM definition of maps, layers, layouts, and layout elements as well as edit their xml.
