How to run the query in FGDB using ArcGIS Pro SDK.Net
1544
05-30-2022 11:15 PM
by Anonymous User
Not applicable
I'm using LabelBuilder to assign labels to the events posted on the line feature class, and there's a button for verifying the label. So, for the SDE database, I implemented it using the code below, but I'm not sure how we can do it in FGDB.
For FGDB I tried using QueryDef but getting the Error : SQL statement invalid
string[] message = TxtBoxDescription.Split('+');
Geodatabase fileGeodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(MapGlobal.Instance.databaseConnection.EventCatalogPath)));
QueryDef queryFilter = new QueryDef
PrefixClause = message[0],
Tables = TableName,
using (RowCursor cursor = fileGeodatabase.Evaluate(queryFilter, false))
while (cursor.MoveNext())
using (Row row = cursor.Current)
 // code here
Could someone please assist me by providing a code snippet for the same?
Thanks in advance!
by Anonymous User
Not applicable
I used the code below, and it worked as expected.
QueryDef queryDef = new QueryDef
Tables = TableName,
SubFields = SelectedColumnName,
using (RowCursor cursor = fileGeodatabase.Evaluate(queryDef))
// code here
Thanks!
Aashis
by Esri Contributor
Sample Pro snippets
QueryDef concepts
An SQL prefix clause supports NoneDISTINCT, ALL, and TOP. An SQL postfix clause supports NoneORDER BY, and GROUP BY
TOP is only supported by SQL Server databases.
by Anonymous User
Not applicable
Tables = TableName,
// code here
Thanks!
Aashis
by Esri Contributor
Glad to be of help.
