How to query all rows from a joined table?
3233
08-13-2020 09:29 AM
Jan-Tschada
We tried to query all rows from a feature layer having a joined table and obtain all row values. When we are using the IDisplayTable::GetFieldDescription method all fields (also the joined fields) are returned, but when we are iterating through the RowCursor returned by IDisplayTable::Search only the values of the "origin table" are returned any access using a field index targetting a field from the joined table by Row::GetValue(fieldIndex) leads to a null reference.
Is this a known issue or do we need to downcast from FeatureLayer/StandaloneTable, or just access the row values using a different approach?
Thanks in advance.
Product Manager
Developers and Location Services
Germany and Switzerland
Jan-Tschada
Any ArcGIS Pro SDK Join expert out there? Rich Ruh‌
Product Manager
RichRuh
Hi Jan,
I'm not that familiar with the layer-level query routines that you're using.  Have you tried just calling FeatureLayer.GetFeatureClass() and querying against that?
--Rich
Wolf
by Esri Regular Contributor
Hi Jan,
 I just tried this using release 2.6 and it is working for me.  In my test I have a feature layer that is joined to a table (both the feature layer and the table are in the TOC).  I retrieve the feature layer for the query from the map using:
var featureLayer = MapView.Active.Map.Layers.OfType<FeatureLayer>().Where (l => l.Name.Equals (...));
In my sample I only query the selected features, however, I see all values including the values of the joined table:
QueryFilter qf = new QueryFilter()
    ObjectIDs = featureLayer.GetSelection().GetObjectIDs()
using (var rowCursor = featureLayer.Search(qf))
    while (rowCursor.MoveNext())
        using (var anyRow = rowCursor.Current)
            foreach (var fld in anyRow.GetFields().Where(fld => fld.FieldType != FieldType.Geometry))
                // includes all 'joined' field names
                var fieldName = fld.Name; // fld.AliasName
                // get all field values
                var fieldValue = (anyRow[fld.Name] == null) ? string.Empty : anyRow[fld.Name].ToString();
OSINT_ENGINEER
Finally we solved the issue. We implemented a kind of wrapper before accessing the underlying RowCursor and this custom implementation did not handled the GetTableDefinition exception correctly when the layer or standalone table is having a join. Sometimes it is really helpful by just letting someone know which things are not related to the problem.
Thank you so much for narrowing this down.
ThiPham12
Hi Wolf,
Would your query sample above also work for querying geodatabase tables? If not, how would you modify it? Thanks!
