how to pass string or array from .pyt to my dockpane (xaml.cs)
3864
11
10-25-2023 07:39 AM
nadja
it seems like a basic question, but even with the documentation and other posts I cannot get it to work properly. I've got a Python-Toolbox in which I establish the connection to a ArcSDE using a connection file. now I would like to list the content of the ArcSDE in my dockpane (because it looks prettier). I can list the content of my dockpane in my Python-Toolbox and display them. It seems that it's also correct how I pass them back (at least there is no error message). But I don't see how I can access the returned strings and arrays. How do I pass my ArcSDE content as string or array (or anything else) to my dockpane?
here is what I've got in my Python Toolbox:
import arcpy
from tkinter import messagebox
from osgeo import gdal
import os
import ast
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "Toolbox"
        self.alias = "toolbox"
        # List of tool classes associated with this toolbox
        self.tools = [ArcSDEContent]
def read_sde():
    if os.path.exists(os.environ['AppDAta']+"/Esri/ArcGISPro/Favorites/xxx.sde"):
      sde_connfile = os.environ['AppDAta']+"/Esri/ArcGISPro/Favorites/xxx.sde"
        conn = arcpy.ArcSDESQLExecute(sde_connfile)
        sql = "select t.name as mytype,i.name as myname,  \
            CASE \
            WHEN has_table_privilege(user,i.name,'SELECT') THEN 1 \
            ELSE 0 \
            END AS mypriv \
            FROM GDB_itemtypes t \
            right join GDB_items i \
            ON i.type = t.uuid \
            where t.name in ( \
            'Tin', \
            'Geometric Network', \
            'Survey Dataset', \
            'Schematic Dataset', \
            'Table', \
            'Feature Class', \
            'Raster Dataset', \
            'Raster Catalog', \
            'Network Dataset', \
            'Terrain', \
            'Parcel Fabric', \
            'Mosaic Dataset', \
            'Utility Network', \
            'Parcel Dataset' \
        try:
            sql_return = conn.execute(sql)
            layer_files = []
            layer_schemas = []
            for i in sql_return:
              if i[2] == 0:
                continue
              layer_type = i[0]
              layer_fullname = sde_connfile + '/' + i[1]
              layer_name = i[1].split('.')[1] + '.' + i[1].split('.')[2]
              layer_shortname = i[1].split('.')[2]
              layer_schema = i[1].split('.')[1]
              if layer_schema not in layer_schemas:
                layer_schemas.append(layer_schema)
           layer_files.append([layer_name,layer_shortname,layer_schema,layer_fullname,layer_type])
            layer_schemas.sort()
            layer_files.sort()
            return layer_files, layer_schemas
        except Exception as err:
            sql_return = False
    else:
      messagebox.showinfo(title="test 2", message="sde file does not exist")
class ArcSDEContent(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "ArcSDE Content"
        self.description = ""
    def getParameterInfo(self):
        """Define parameter definitions"""
        params = []
        params.append({
            'name': 'layer_files',
            'displayName': 'Layer Files',
            'datatype': 'String',
            'parameterType': 'Derived',
            'direction': 'Output'
        params.append({
            'name': 'layer_schemas',
            'displayName': 'Layer Schemas',
        return params
    def isLicensed(self):
        return True
    def updateParameters(self, parameters):
        return
    def updateMessages(self, parameters):
        return
    def execute(self, parameters, messages):
      layer_files, layer_schemas = read_sde()
        # Set the output parameters with the results
      parameters[0].value = ";".join(layer_files)  # Join the list to a string
      parameters[1].value = ";".join(layer_schemas)
and in my dockpane.xaml.cs I've got:
        private async void ReadArcSDE(object sender, RoutedEventArgs e)
            string installPath = System.IO.Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly().Location);
            string toolboxPath = System.IO.Path.Combine(installPath, "MyPythonToolbox.pyt\\ArcSDEContent");
            IGPResult result =  await Geoprocessing.ExecuteToolAsync(toolboxPath, null, null, null, null, GPExecuteToolFlags.InheritGPOptions);
thanks for any hint
swiss_parks_network_nbernhard
thank you @GKmieliauskas
I tried to adapt my code to your sample. my python:
  try:
    string_to_pass = "Your output value"
    arcpy.SetParameter(4, string_to_pass)
    return
  except Exception as e:
    arcpy.AddError(f"An error occurred: {str(e)}")
and then in my xaml.cs:
    string toolboxPath = System.IO.Path.Combine(installPath, "xxxx.pyt\\ArcSDEContent");
    var resultValues = result.Values;
    foreach (string val in resultValues)
                 ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(val, "values val");
it seems to work until line 7 "var resultValues" - at least until there I don't get an error message (unless I try result.Result.Values). But as soon as I try to access / print my result values (see line 9 to 12), I get "System.NullReferenceException: 'Object reference not set to an instance of an object'". where is my mistake?
GKmieliauskas
You need to check 'result' as in my last comment. Your geoprocessing tool could fail or etc. I don't have possibility to check, but it seems for your geoprocessing  calling code could be like this:
                var gpResult = await Geoprocessing.ExecuteToolAsync(fullToolPath,                     parameters, null, null, (eventName, o) => GPHelper.ProcessGPEvent(eventName, o), GPExecuteToolFlags.AddToHistory);
                string errMsg = string.Empty;
                if (gpResult.IsFailed)
                    throw new Exception("Tool failed");
                else
                    var resultValues = gpResult.Values;
                    if (resultValues == null)
                        throw new Exception("Nothing is returned");
                    else
                        if (resultValues.Count > 0)
                             // reading output parameters
