How to open a cursor based on a query (not QueryDef)?
1473
04-22-2022 09:15 AM
FridjofSchmidt
In ArcObjects it is possible to return a cursor based on a query string with ISqlWorkspace.OpenQueryCursor(myQuery). I was wondering if and how this is possible in the ArcGIS Pro SDK.
The query is in fact calling an Oracle stored procedure which returns a number based on an input number:
var myQuery = string.Format("select forstgis.wimsidutil.nextwimsid({0}) from dual", unitId);
I tried to put this into a QueryDef and use Geodatabase.Evaluate(queryDef) like this:
            var queryDef = new QueryDef
                Tables = "dual",
                SubFields = string.Format("forstgis.wimsidutil.nextwimsid({0})", unitId)
However, Evaluate in this case throws a COMException (HRESULT: 0x80040351).
I know there is also the ArcSDESQLExecute class, but I would prefer not to use Geoprocessing in this case.
FridjofSchmidt
Found a solution based on the Database class instead of Geodatabase:
var query = string.Format("select cast(forstgis.wimsidutil.nextwimsid({0}) " +
    "as number(38,0)) id from dual", unitId);
using (var queryDesc = database.GetQueryDescription(query, "QueryLayer"))
    queryDesc.SetObjectIDFields("id");
    using (var table = database.OpenTable(queryDesc))
    using (var cursor = table.Search())
        while (cursor.MoveNext())
            using (var row = cursor.Current)
                return (int)row[0];
FridjofSchmidt
                return (int)row[0];
