does anyone have any c # code that can load the shapefile into the current map and add the same reference so that it fits well into the original map?
Thank for any advice
To add a data source to your current active map (or another map) you can use the snippet:
public Task<Layer> AddLayer(string uri)
return QueuedTask.Run(() =>
Map map = MapView.Active.Map;
return LayerFactory.Instance.CreateLayer(new Uri(uri), map);
}and you would call the method like this:
var pathToSource = @"c:\temp\test.shp";
Layer lyr = await AddLayer(pathToSource);and some examples for pathToSource
