How to load shapefile layer to current map?
2172
10-17-2021 10:20 PM
DavidMrázek
Hello,
does anyone have any c # code that can load the shapefile into the current map and add the same reference so that it fits well into the original map?
Thank for any advice
Wolf
by Esri Regular Contributor
To add a data source to your current active map (or another map) you can use the snippet:
public Task<Layer> AddLayer(string uri)
    return QueuedTask.Run(() =>
        Map map = MapView.Active.Map;
        return LayerFactory.Instance.CreateLayer(new Uri(uri), map);
and you would call the method like this:
var pathToSource = @"c:\temp\test.shp";
Layer lyr = await AddLayer(pathToSource);
and some examples for pathToSource
  1.  FeatureClass inside a FileGeodatabase: C:\Data\MyFileGDB.gdb\Census
  2. A shape file inside a folder: \\Machine\SharedFolder\Census.shp
  3. Raster Dataset inside a FileGeodatabase: C:\Data\MyFileGDB.gdb\DEM
  4. An image file inside a folder: \\Machine\SharedFolder\Imagery.tif
  5. A map service layer: http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer
  6. A feature layer off a map or feature service: http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0
  7. A .lprx or .lpkx file: \\Machine\SharedFolder\Fires.lyrx
Wolf
DavidMrázek
Thank you!!!
