How to get the unit of a Geometry? Or gets the distance in specified units between two geometries
1234
03-05-2022 04:28 AM
YangYifei
Hi there. I'm trying to get the distance of two geometries by this api ArcGIS Pro 2.8 API Reference Guide - Distance Method—ArcGIS Pro.
But I found that I will get a result in meter from some .shp files. But when I use another .shp file, it seems to be kilometer...
I'm so confused about it. And I have searched API document, and found that I can set the LinerUnit if I use  GeodesicDistance refers in ArcGIS Pro 2.9 API Reference Guide - GeodesicDistance(Geometry,Geometry,LinearUnit) Method—ArcGIS Pr...
But I have used 2.8 API, there's no this implement...
And I have tried to get the elevation unit format of the map, they're all meter in different .shp file.
So how can I get the unit type of a Geometry? Or can I change the distance result to meter directly?
Thanks a lot!
Tags (1)
YangYifei
I found that GeodesicDistance  can return the distance in meteres by default
ArcGIS Pro 2.8 API Reference Guide - GeodesicDistance Method—ArcGIS Pro
So I can use it to get the distance in LinearUnit.Meteres
And then convert it to other LinearUnit. It solved my problem.
Thank you so much!
CharlesMacleod
use the geometry spatial reference:
https://pro.arcgis.com/en/pro-app/2.8/sdk/api-reference/#topic8178.html
specifically, its Unit property.
https://pro.arcgis.com/en/pro-app/2.8/sdk/api-reference/#topic8797.html
In your case it sounds like it is of type LinearUnit.
YangYifei
Thanks for your reply!
I found that the special reference of my geometry is AngularUnit.Degrees.
And I try to convert it to LinearUnit.Meters.
But there's no such implement that can convert the unit from angular to linear...
So any other methods can I try?
Thank you!
YangYifei
Thank you so much!
