How to get the TooltipHeading
946
06-20-2018 08:25 AM
BerendVeldkamp
Occasional Contributor II
I have a simple ArcGIS Pro add-in, with a button defined in the daml:
<button id="ProAppModule2_Button1" caption="Click me" className="Company.Project.Button1"
     loadOnClick="true"
     smallImage="Images\sample16.png"
     largeImage="Images\sample32.png"
     keytip="This is a tip">
    <tooltip heading="This is a heading">Tooltipbody<disabledText /></tooltip>
</button>‍‍‍‍‍‍‍‍
However, inside the button class the TooltipHeading is an empty string. (Tooltip contains the text 'Tooltipbody').
What am I missing?
Tags (3)
UmaHarano
Hi Berend,
Here is a snippet for this: Get a button's tooltip heading
Thanks
Uma
EvanMosher
New Contributor II
In this example there is a open and close tag for disabledText, in your example you only have the 1 tag. This might be the cause?
<tooltip heading="Select By Rectangle">Select features by clicking them or dragging a box around them.
<disabledText></disabledText>
</tooltip>‍‍‍‍‍‍
-Evan
BerendVeldkamp
No, that's basic XML: <disabledText></disabledText> is exactly equal to <disabledText />
UmaHarano
Hi Berend,
Thanks
Uma
BerendVeldkamp
Great. All my buttons inherit from a single class (which in turn inherits from Button) so I put this in the base constructor:
var wrapper = FrameworkApplication.GetPlugInWrapper(ID);
TooltipHeading = wrapper.TooltipHeading;
Still, I don't really understand why the TooltipHeading is empty in the first place.
