How to get the proper reason for Edit Operation Failed.. error.
1116
06-08-2021 11:29 PM
TapasChakrabarty
I am trying to edit a Date field on the attribute table with some other data type. In this case, my EditOperation is getting failed which is correct. But when I try to capture the ErrorMessage of the EditOperation it shows me "Edit Operation Failed....". But I want a more specific error message as to why the Edit Operation failed. How can I get the specific reason for the Edit operation failed?
Below is my code snippet:
If Not (FieldValue = Nothing) Then
inspector(fieldName) = FieldValue.ToString()
Else
inspector(fieldName) = ""
End If
EditOp.Modify(inspector)
Dim result = EditOp.Execute()
If Not result Then
exception = EditOp.ErrorMessage()
End If
SDK 2.8, ArcGIS Pro 2.8, VS2019.
Wolf
by Esri Regular Contributor
I think the problem is caused when you assign a string data type to a date field.  Try to assign a DateTime type to date fields.
TapasChakrabarty
Yes, you are right. I know the reason. But I want to display the error on UI so needed the particular reason why the edit operation failed. I am able to get the error message as "Edit Operation failed.". But I want to display Edit operation failed due to a data type mismatch.
Wolf
Unfortunately the underlying API doesn't return detailed error messages depending on the data source that is used for editing.  I will forward this post to the ArcGIS Pro's Dev Team to re-iterate that this is an issue.
