How to get return value from python tool
8597
11
09-25-2020 12:07 AM
by Anonymous User
Not applicable
Hi Guys,
I am currently trying to find out how to get return back value from python tool box.
Below is the snippet of Python and C#, not sure why when I run the code whole ArcGIS pro hang.
I have done similar way before but working properly but not sure why it is happening with these.
Python snippet (ouputLayerInfo value is the one want to return to c# side)
# -*- coding: utf-8 -*-
import arcpy
import json
import sys
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "Toolbox"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [GetLayerDataConnections]
class GetLayerDataConnections(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "GetLayerDataConnections"
        self.description = "Get Layer Data Connections"
        self.canRunInBackground = True
    def getParameterInfo(self):
        """Define parameter definitions"""
        # First parameter
        param0 = arcpy.Parameter(
            displayName="Layer File Location",
            name="Layerfile_location",
             datatype="GPString",
            parameterType="Required",
            direction="Input")
        params = [param0]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        layerfileLocation = parameters[0].valueAsText
        ouputLayerInfo = []
        aLayerFile = arcpy.mp.LayerFile(layerfileLocation)
        layerList = aLayerFile.listLayers()
        for lyr in layerList:
            if lyr.supports("DATASOURCE"):
                conProp = lyr.connectionProperties
                name = lyr.name
                tmpStr = ("{LayerName:'"+name+"',ConnectionProperties:"+ json.dumps(conProp)+"}")
                ouputLayerInfo.append(tmpStr)
        return
c# snippet
 private void GetLayerDataSourceInfo(string layerfilePath, string toolboxPath)
            try
                var ps = new ProgressorSource("Start retrieving datasource.....");
                var arguments = Geoprocessing.MakeValueArray(layerfilePath);
                var gpResult = Geoprocessing.ExecuteToolAsync(toolboxPath, arguments);
                using (var progress = new ProgressDialog("Retrieving datasources"))
                    var status = new ProgressorSource(progress);
                    progress.Show();
                    gpResult.Wait();
                    progress.Hide();
                IGPResult ProcessingResult = gpResult.Result;
                if (ProcessingResult.IsFailed)
                    string errorMessage = "";
                    foreach (IGPMessage gpMessage in ProcessingResult.Messages)
                        errorMessage += $"{{Error Code: {gpMessage.ErrorCode}, Text :  {gpMessage.Text} }}";
                    MessageBox.Show($"Geoprocessing fail {Environment.NewLine}{errorMessage}");
                else
                    string outvalue = ProcessingResult.ReturnValue;
                    Console.WriteLine(outvalue);
                    MessageBox.Show($"Return value {Environment.NewLine}" + outvalue);
            catch (Exception exce)
               //log
Uma Harano‌, Wolfgang Kaiser
by Anonymous User
Not applicable
Thank Mody Buchbinder‌,
I did try it before I post it, Actually I should try it again since Wolfgang Kaiser‌ callback does not make application hang.
After I reuse, with output as pure GPString, I manage to get the return output from returnvalue from IGPResult and got all parameter value back in Parameters array from IGPResult as well.
That's helpful reminder.
by Anonymous User
Not applicable
Latest update of this question,
Actually noticed I don't need to use python tool to retrieve layer datasource information from lyrx or mapx files.
