How to get a single feature from an object id
3009
04-27-2022 07:24 AM
DaveLewis73
I have what I believe to be a very simple question, but I cannot find an answer for it.  Is there a method of getting a single feature from an object id (OID)?  In ArcObjects this can be accomplished by simply calling GetFeature() on a feature class object and passing in an object id.  An example would be IFeature feature = featClass.GetFeature(100).
Aashis
by Esri Contributor
You can search by ObjectId using QueryFilter.
public void SearchFC(FeatureClass featureClass, IReadOnlyList<long> objectIDs)
      QueryFilter queryFilter = new QueryFilter()
        ObjectIDs = objectIDs
      using (RowCursor rowCursor = featureClass.Search(queryFilter))
        while (rowCursor.MoveNext())
          using (Feature feature = rowCursor.Current as Feature)
            // use feature
DaveLewis73
Yeah, that is the direction that I figured that I would have to go.  I ended up writing a function that uses a QueryFilter:
internal Task<int> GetMaxCellNumber()
    return QueuedTask.Run<int>(() =>
        FeatureClass featClass = GridLayer.GetFeatureClass();
        int num = featClass.GetCount();
        List<long> oids = new List<long>();
        oids.Add(checked(num - 1));
        IReadOnlyList<long> objectIDs = oids.AsReadOnly();
        RowCursor cursor = featClass.Search(queryFilter);
        Row row = null;
        if (cursor.MoveNext())
            row = cursor.Current;
        if (row == null)
            return 0;
        return (int)row["Cell_Num"];
Does this seem like a good solution or can it be made simpler?  It just seems a little clunky.
Stefan_Offermann
I also am looking for this one-liner as I know this was so easy to use in ArcObjects. Creating a filter and cursor object seems to bloating when comparing it to good ol' featClass.GetFeature(oid) 😐
GKmieliauskas
You can use Inspector class Load method. There is Load method overload Load(Table,Int64) where parameters are table/featureclass and objectid. Then you can read attributes and geometry using inspector object.
