How to find a point along a line at a specific measure using the Pro SDK
983
08-17-2018 07:07 AM
by Anonymous User
Not applicable
Need to be able to find a point along an M-enabled line at a specific measure.
NarelleChedzey
Hi Robert,
There is currently no API in Pro for location referencing functionality, but if your measure values relate to the length of your lines or are calculated according to a start measure and end measure for the lines you should be able to do this.
First you would need to interpolate the distance along the line that the measure value relates to.  Then you could use the GeometryEngine.Instance.QueryPoint function to obtain the point.
ArcGIS Pro 2.2 API Reference Guide - GeometryEngine QueryPoint
Hope this helps.
Narelle
by Anonymous User
Not applicable
Thanks Narelle, that should do what I need.
-bob
