How to enable Map tools when we select only Annotation Feature from Create Features window in ArcGIS pro SDK
1208
05-24-2021 11:36 PM
sudhansuMishra
We are working on a project using ArcGIS Pro SDK. The following is the problem statement.
User wishes to enable  map tools in ArcGIS Pro Add-In , when user select only Annotation Feature Class from Create Features Window.
EX - We used below condition in config.dmal file for Line features. condition="esri_editing_LineSketch_condition"
Similarly we need condition that work for Annotation Feature Class.
Your inputs/ideas are most appreciated .
Tags (1)
CharlesMacleod
you could probably make one. Something like....
<dependencies>
<dependency name="Editing.daml" />
</dependencies>
<conditions>
<insertCondition id="my_AnnoSketch_condition">
      <state id="esri_editing_annoSketching"/><!-- this state is defined in Editing.daml -->
</insertCondition>
