How to download a single sample from the GitHub
3033
6
06-14-2023 12:28 PM
BrianBulla
Honored Contributor
Is there a way to download just a single code sample from GitHub?  I'd like to have a look at this one, but I don't need to download every sample....just this one:
https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Framework/DockpaneSimple
BrianBulla
Honored Contributor
OK, this seems to work....but is there a way to do this directly in GitHub??
https://download-directory.github.io/
DanPatterson
MVP Esteemed Contributor
Many suggestions and options... but they depend on your interpretation of "directly"
git - Download a single folder or directory from a GitHub repo - Stack Overflow
which precludes a simple right-click
... sort of retired...
BrianBulla
Honored Contributor
Yeah, I saw that article, but I was just thinking there has got to be a way to do it directly in GitHub.....but maybe not?
Thanks!
DanPatterson
If available, a left=click works for me
(One from my Github as an example)
BrianBulla
Honored Contributor
Yes, the "Code" button above only seems to appear if you want to download ALL of the samples (ie. the entire tree).  But if you want to pick and choose what samples to download, there is no option for that....at least not directly in GitHub.
For example, this you can download directly:  https://github.com/Esri/arcgis-pro-sdk-community-samples
But this (a single branch from the above link), you cannot:  https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Framework
It's not a huge problem, just kind of annoying.
DanPatterson
I guess that is the way they have it set up.  Everyone of my packages/folders has a code button
