How to display attribute table with ArcGIS PRO SDK C#?
3544
5
02-11-2020 02:18 PM
Amadeus111
Occasional Contributor II
I would like to open the attribute table for a selected layer. I was able to create table from a feature layer and have access to it. However, I do not know how to put that into the display like right clicking on the layer and opening the attribute table.
public void create_Layer()
   string shp_path = this.ComboBox_shps.Text;
   int indexNumber = 0;
   if (shp_path != null && shp_path != string.Empty)
         System.Uri shp_filepath = new System.Uri(@shp_path);
         QueuedTask.Run(() =>
   var shp_layer = LayerFactory.Instance.CreateLayer(shp_filepath, MapView.Active.Map, indexNumber,    shp_path.Substring(16));
   //Get the active map view.
   var mapView = MapView.Active;
   if (mapView == null)
      return Task.FromResult(false);
    else
      var selectedLayer = mapView.GetSelectedLayers()[0];
      if (selectedLayer is ArcGIS.Desktop.Mapping.FeatureLayer)
            ArcGIS.Core.Data.Table a_table = (selectedLayer as FeatureLayer).GetTable();
            int gugu = a_table.GetCount();
            MessageBox.Show(gugu.ToString()); // I can get the row count here
   //Zoom to the selected layers in the TOC
   return mapView.ZoomToAsync(selectedLayer);
UmaHarano
Here is a button OnClick method that opens the Attribute table for a layer:
protected override void OnClick()
      var lyrs = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>();
      MapView.Active.SelectLayers(lyrs.ToList());
      var openTableBtnCmd = FrameworkApplication.GetPlugInWrapper("esri_editing_table_openTablePaneButton") as ICommand;
      if (openTableBtnCmd != null)
        // Let ArcGIS Pro do the work for us
        if (openTableBtnCmd.CanExecute(null))
          openTableBtnCmd.Execute(null);
Uma
UmaHarano
Hi
There are multiple ways to display the contents of your table. You can use a WPF Datagrid control to display the table.
Another option is to use the Pro SDK Table Control. Here is a sample that shows how to do that:
TableControl Sample
Uma
Amadeus111
Hi
I tried TableControl Sample previously. It was giving an error :
Severity Code Description Project File Line Suppression State Error Could not load file or assembly 'ArcGIS.Desktop.DataGrid.Contrib.Wpf, Version=13.1.580.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86' or one of its dependencies. The system cannot find the file specified. TableControl TableControlDockpane.xaml 77
for creating table control
<editing:TableControl AutomationProperties.AutomationId="_tableControl" x:Name="tableControl"
Grid.Row="1" VerticalAlignment="Stretch" HorizontalAlignment="Stretch"
TableContent="{Binding Path=TableContent}"
RowContextMenu="{StaticResource MyRowContextMenu}"
SelectedRowContextMenu="{StaticResource MyRowContextMenu}"
</editing:TableControl>
I tried also using WPF Datagrid but could not figure it out. It tells I am calling the wrong thread.
DataGrid_A_Table.DataContext = a_table; // I cann not pass pro table to Datagrid
I will check one more time.
I even tried pressing hot keys (Ctrl + T) programmatically for selected layer but no luck either.
I could not find the DAML ref ID for that button  either
I just would like to trigger to open attribute table like right clicking on the layer and click on the attribute table button.
Thanks!
Oz
UmaHarano
Uma
Amadeus111
Thank you for the response! I am busy with something else but I will try this ASAP and come back with results.
Oz
Amadeus111
Perfect! It works now.
Thank you for your help!
Oz
