How to create a custom ExportFormat
470
04-22-2026 06:58 AM
BerendVeldkamp
I was looking at creating a custom ExportFormat, but was wondering where to implement the actual export method. I was expecting an overridable Execute() method or something like that, but can't find it. The documentation doesn't really go into details.
I guess the basics should be something like this:
internal class MyExporter : ExportFormat
    public MyExporter(): base()
        _extensions.Add("my");
    public override bool ValidateOutputFilePath()
        return true;
internal class Button1 : Button
    protected override void OnClick()
        QueuedTask.Run(() =>
            var e = new MyExporter();
            e.OutputFileName = @"d:\temp\test.my";
            MapView.Active.Export(e);
CharlesMacleod
The api is not extensible in that regard. You would basically have to write something like:
MyModule.Current.MyCustomExportMethod(MapView.Active, ....) assuming that u cld actually access, via the available public api, the relevant properties, etc. u wld need for implementation of your custom export
