How to convert screen pixels to map units
3838
5
02-24-2022 10:57 AM
DaveLewis73
I am looking to create polygons (halos/rings) around the mouse cursor.  I have figured out how to create the halos by using System.Windows.Forms.Control.MousePosition and then converting into lat/long by using MapView.Active.ScreenToMap.  I have also used a MouseHook from the Win32Api to give me a MouseMove event.  This allows me to associate the polygon to the mouse cursor and move it around the map as an overlay.
The problem that I am having now is that I can only create a polygon (halo/ring) with a radius in pixels.  I need to be able to use map units, like feet, meters, miles, kilometers, etc.  For example, I want to create a polygon (halo/ring) that has a radius of 100 feet.
Is there some way to accomplish this?
The following is a method that I am using that takes pixels to create the halo, just in case it would be of help to someone:
private ArcGIS.Core.Geometry.Polygon CreateHaloPolygon(MapPoint mapPoint, int pixels, out double radius)
    // Get the halo radius
    Point screenPoint = MapView.Active.MapToScreen(mapPoint);
    Point radiusScreenPoint = new Point((screenPoint.X + pixels), screenPoint.Y);
    MapPoint radiusMapPoint = MapView.Active.ScreenToMap(radiusScreenPoint);
    radius = GeometryEngine.Instance.Distance(mapPoint, radiusMapPoint);
    // Build a circle geometry
    Coordinate2D coord2D = new Coordinate2D(mapPoint);
    EllipticArcSegment arcSegment = EllipticArcBuilder.CreateEllipticArcSegment(coord2D, radius,        esriArcOrientation.esriArcClockwise, SpatialReferences.WGS84); //MapView.Active.Map.SpatialReference);
    PolygonBuilder polyBuilder = new PolygonBuilder(new[] { arcSegment });
    return polyBuilder.ToGeometry();
DaveLewis73
I have solved this issue by using the GeometryEngine.Instance.GeodesicEllipse method.  It takes in a GeodesicEllipseParamter containing all of the necessary parameters to create the ellipse and a spatial reference.  Included in the parameters is the radius and the linear units to use.  The following is a code snippet of creating the geodesic ellipse:
private ArcGIS.Core.Geometry.Geometry BuildBufferEllipse(MapPoint mapPt, double radius, string linearUnits)
    var ellipseParams = new GeodesicEllipseParameter
        Center = new Coordinate2D(mapPt),
        AxisDirection = 0.0,
        LinearUnit = GetLinearUnits(linearUnits),
        OutGeometryType = GeometryType.Polygon,
        SemiAxis1Length = radius,
        SemiAxis2Length = radius,
        VertexCount = 99
    return GeometryEngine.Instance.GeodesicEllipse(ellipseParams, MapView.Active.Map.SpatialReference);
KenBuja
Does the snippet Calculate Selection tolerance in map units help at all in converting from screen pixel to map units?
DaveLewis73
Ken,
Thank you for your reply.  Unfortunately, I have already come across that sample and it doesn't work for me.
GKmieliauskas
DaveLewis73
Gintautas,
Thanks for the link.  I looked it over and I did find some interesting information concerning LinearUnits, but I didn't find an answer to my question regarding the conversion of screen coordinates in pixels to map units.
DaveLewis73
        VertexCount = 99
