How to connect to a Workflow Manager Portal and Item in order to get a list of jobs?
388
01-27-2025 02:05 PM
Gfreitag
I'm trying to create an addin which contains a button. When pressed, this button will launch a Workflow Manager job in Pro. First, I gather I need to be able to get a WorkflowClientModule, or create a WorkflowConnection (I'm still a bit unsure). However on the WorkflowModule.ConnectAsync() method, a caveat reads "A workflow connection instance should already exist in the project. If not, add a workflow connection prior to calling this method." How would I do this?
I notice that I need to select both a portal and a workflow item in Pro, if I were to do this manually. I'm not sure how to do this using the SDK.
I'm already a bit confused, because a lot of the documentation out there is for Workflow Manager (Classic). Thank you in advance!
Tags (3)
Gfreitag
I clarified the issue for myself slightly, I realize I am required to connect to the portal and workflow item in Pro directly to be able to get a list of jobs or other tasks. I would still like to be able to connect programmatically, if possible.
LalaineLam
@GfreitagWe do not expose a way to programmatically connecting to a workflow item outside of interacting with the Workflow Pane. However, this is good feedback which I will bring back to the team.
Thank you.
Workflow Manager Team
