I am able to connect to an sde geodatabase and obtain a handle on a raster dataset, but I can't figure out how to add this dataset to my map. I don't see how I would use a Uri since it doesn't exist in a file, and I don't know how to obtain an Item or CIMDataconnection from a RasterDataset type - since these are the three data types allowed in LayerFactory.Instance.CreateMosaicLayer().
var connectionProps = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
AuthenticationMode = AuthenticationMode.OSA,
Instance = "instance",
Database = "sdeDOQTX1996",
var doq96GDB = new Geodatabase(connectionProps);
var doqDataset = doq96GDB.OpenDataset<RasterDataset>("sdeDOQTX1996.DBO.Zone14_mosaic");
//LayerFactory.Instance.CreateMosaicLayer(?, map, 0);
Devon,
That is a good question. You don't need the raster dataset object to create a layer, you have all the information you need before that step already. Once you have a geodatabase object, you can create a CIMStandardDataConnection object using it and then use that to create a mosaic layer. Sample code below.
// Create the data connection object.
string workspaceConnectionString = geodatabase.GetConnectionString();
CIMStandardDataConnection dataConnection = new CIMStandardDataConnection();
// Setup the data connection object.
dataConnection.WorkspaceFactory = WorkspaceFactory.SDE;
dataConnection.WorkspaceConnectionString = workspaceConnectionString;
dataConnection.DatasetType = esriDatasetType.esriDTMosaicDataset;
dataConnection.Dataset = "sdeDOQTX1996.DBO.Zone14_mosaic
// Create the layer.
rasterLayer = (MosaicLayer)LayerFactory.Instance.CreateLayer(dataConnection, map);
You can create a raster, mosaic or image service layer using the CreateLayer method.
Hope that helps.
-Prashant
Devon,
Hope that helps.
-Prashant
Great, thanks! I just couldn't find any docs on how to use a CIMDataConnection.
I had a similar issue trying to add a table with geometry from a non SDE database. I found that after I had a refrence to the table I could call the GetDataConnection method and it worked.
Here is my code in case it helps others.
DatabaseConnectionProperties connectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.Hana) { AuthenticationMode = AuthenticationMode.DBMS, Instance = @"mydbinstance", User = "username", Password ="*****" }; using (Database db = new Database(connectionProperties)) { QueryDescription qds = db.GetQueryDescription(" select GEF_OBJECTID, GEF_OBJKEY, OBJNR, ERNAM, ERDAT, KTEXT, IDAT2, AENAM, ARTPR, GEF_SHAPE from schema.tablename", "MySelect"); Table pTab = db.OpenTable(qds) FeatureLayer pFL = (FeatureLayer) LayerFactory.Instance.CreateLayer(pTab.GetDataConnection(), MapView.Active.Map, 0); }
var connectionProps = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer) { AuthenticationMode = AuthenticationMode.OSA, Instance = "instance", Database = "sdeDOQTX1996", }; var doq96GDB = new Geodatabase(connectionProps); var doqDataset = doq96GDB.OpenDataset<RasterDataset>("sdeDOQTX1996.DBO.Zone14_mosaic"); //LayerFactory.Instance.CreateMosaicLayer(?, map, 0);
