How do you determine which map frame is active in a layout?
2051
03-30-2018 10:24 AM
TomFlahive
I would like to resize a map frame in a layout.  If the layout has more than one map frame, as in the screenshot below, how can I determine which map frame is currently the active map frame (which shows as bolded in the Contents pane)?
Select map frame in a layout with multiple map frames.
I checked the MapFrame object and the Layout object, but did not see any properties that would tell me which map frame is active.
JeffBarrette
This propery has not yet been exposed but thank you for bringing this to our attention - we will expose it in an upcoming release.
JeffBarrette
TomFlahive
Sounds good.  Thank you Jeff.
JeffBarrette
This has been addressed for the ArcGIS Pro 2.2 release.  There is a r/o property called ActiveMapFrame on the LayoutView class.
//ActiveMapFrame
LayoutView lytView = LayoutView.Active;
if (lytView == null)
System.Windows.MessageBox.Show("No LayoutView");
return;
MapFrame mf = lytView.ActiveMapFrame;
if (mf == null)
System.Windows.MessageBox.Show("No MapFrame");
else
System.Windows.MessageBox.Show(mf.Name);
