How do you change the label style?
16605
7
10-24-2017 10:49 AM
MichaelStranovsky
I am looking for a way to change the font size, style(Bold) and add a mask(Halo) through the sdk.
UmaHarano
Hi Michael,
You should be able to adjust the settings of a MapFrame in a Layout using the SetCamera method.  Check out the code snippets on this page of the API Reference guide: topic11124.html
Thanks!
Uma
UmaHarano
Hi
You can access the Feature Layer's LabelClasses and the TextSymbol through the CIM to accomplish this.  Here is a snippet:
        private void ChangeLabel(FeatureLayer lyr)
            var lyrDefn = lyr.GetDefinition() as CIMFeatureLayer;
            var listLabelClasses =  lyrDefn.LabelClasses.ToList();
            var textSymbol = listLabelClasses.FirstOrDefault().TextSymbol.Symbol as CIMTextSymbol; //Gets the text symbol of the label class
            textSymbol.FontStyleName = "Bold"; //set font as bold
            textSymbol.SetSize(10); //set font size
            //Text symbol might not have a halo.
            //So need to create a halo symbol (polygon with a solid fill layer)
            var haloFill = new CIMSolidFill
                Enable = true,
                Color = ColorFactory.Instance.RedRGB,
                ColorLocked = false
            //Define the array of Symbol layers (holds the halo solid fill only)
            var symbolLyrs = new CIMSymbolLayer[]
                haloFill
            //Creates the Polygon symbol with the halo solid fill layer
            var haloSymbol = new CIMPolygonSymbol
                SymbolLayers = symbolLyrs
            //Assign this halo symbol and its size to the text symbol
            textSymbol.HaloSymbol = haloSymbol;
            textSymbol.HaloSize = 1;
            lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
            lyr.SetDefinition(lyrDefn); //set the layer's definition
Thanks
Uma
MichaelStranovsky
Thank you for your help.  It worked like a charm.   One more question though,  how would you change the expression for the label?(the field used to label)
MichaelStranovsky
Thank you, how would you change the label expression(field use for labeling)?
Michael Stranovsky
Spatial Database Administrator
EIT – Enterprise GIS
1660 Ringling Blvd, Sarasota, FL 34236
Office: 941-914-8373
Cell: 941-914-8373
Email: [email protected]<mailto:[email protected]>
Web: www.scgov.net<http://www.scgov.net/>
All email sent to and from Sarasota County Government
is subject to the public record laws of the State of Florida.
To learn more about Florida’s Sunshine Law click here<https://employeenet.scgov.net/Communications/SitePages/Public%20Records.aspx>.
<https://www.facebook.com/SarasotaCountyGovernment/> <https://twitter.com/SRQCountyGov/> <https://www.instagram.com/srqemergencyservices/> <https://www.youtube.com/user/sarasotacounty1> <http://www.linkedin.com/company/27399?goback=.fcs_GLHD_sarasotacountygovernment_false_2_2_2_2_2_2_2_2_2_2_2_2&trk=ncsrch_hits>
UmaHarano
Hi Michael
The LabelClass' Expression property can be used.  Like this:
theLabelClass.Expression = "$feature.POP2000";
Another thing you might find helpful while working with the CIM is to use the arcgis-pro-sdk-cim-viewer.  This will give a view of all the CIM objects, properties that you can manipulate for what you need.
Thanks
Uma
MichaelStranovsky
Okay thank you again
Michael Stranovsky
Cell: 941-914-8373
MichaelStranovsky
Hi Uma,
Is there a way to get at the location settings of the mapframe in the layout through the sdk. I want to adjust the scale and the center x and y.
Michael Stranovsky
Cell: 941-914-8373
UmaHarano
Hi Michael,
Thanks!
Uma
