How do I query a voxel layer data value from give a coordinate?
1106
09-30-2024 08:52 PM
YetaoYang
I have a voxel layer (from netCDF file) in local scene. I want to query the data value of  the voxel layer by a give coordinate (x,y,z). I check the arcgis pro SDK and found that I access the voxellayer and voxelvome and the statistics of the data value such as maxvalue and minvalue:
//Get the first voxel layer in the TOC
 voxelLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<VoxelLayer>().FirstOrDefault();
 if (voxelLayer == null)
    return;
 QueuedTask.Run(() => {
    //access the volume
    var volume = voxelLayer.SelectedVariableProfile;
    var vol_size = volume.GetVolumeSize(); //(double X, double Y, double Z)
    //TODO - use the dimensions
    //vol_size.X, vol_size.Y, vol_size.Z
and also can get the statistics of the data value by:
/var voxelLayer = ... ;
 //Must be on the QueuedTask.Run()
 //get the selected variable profile
 var variable = voxelLayer.SelectedVariableProfile;
 //Must be continuous to have a stretch renderer
 if (variable.DataType != VoxelVariableDataType.Continuous)
   return;
 var renderer = variable.Renderer as CIMVoxelStretchRenderer;
 var color_min = renderer.ColorRangeMin;
 var color_max = renderer.ColorRangeMax;
 //increase color range by 10% of the current difference
 var dif = (color_max - color_min) * 0.05;
 color_min -= dif;
 color_max += dif;
 //make sure we our color range does not exceed the current
 //renderer data range
 if (color_min < variable.GetVariableStatistics().MinimumValue)
    color_min = variable.GetVariableStatistics().MinimumValue;
 if (color_max > variable.GetVariableStatistics().MaximumValue)
    color_max = variable.GetVariableStatistics().MaximumValue;
 but I can not find a way to get the exact data value for a given coordinats (x,y,z)?
Anybody can kind help me?
Thanks!
GKmieliauskas
From my opinion you need to make raster layer from NetCDF file using geoprocessing, then read value from raster layer.
YetaoYang
Thank you!  But this way will be slow for large voxel data for conversing the data type. I think reading the raw netCDF file by a cdf library in C# maybe faster
